Unsuccessful attempt to allocate memory.
Make sure the switch has sufficient memory to handle this event. If it does, then the fault lies with allocating memory for a particular parameter. Reboot switch to see if the problem is solved.
Critical
Out of Memory. %size% bytes.
| Name | Type |
| size | uInt |
